recently had some work done in the bathroom. Plumber had to disconnect the radiator in the bathroom and also in the kitchen (for decorating work). Heating was working fine, while radiators where off the wall, trvs where change in the kitchen, and bedroom (both damaged) but to do this the system (open) was drained.
But the F/E tank did not drain at all but the system did completely. I drained the tank by hand and then turned on the water again, but the system didnt seem to fill, so as a last resort l back filled the system using the overflow/expantion pipe.
the radiators are now full both downstairs and up, system fired up and was running but with the pump heating up, something l dont know if its normal to do so. There is a bit of noise like trapped air. So turned system off bleed pipes and restarted system. But noise like too little water in the system still remains
There is still no movement in the expantion tank. Either way.
Can anybody give me some ideas or help.
Thanks Chris.
Thanks Chris.
