Hi all
I have a British Gas 330+ boiler and the display is showing a F25 fault. From what I can gather its actually a Glow-worm boiler and I've found this manual http://www.glow-worm.co.uk/stepone/data/downloads_sd/6c/00/00/hxi_range.pdf that shows the F25 fault code to be Maximum Temperature Rise Slope (Possible Pump Failure/Air In System).
I'm guessing its the latter, air in system as the radiators have needed bleeding recently.
What's going to be the best way to sort this without having to call out a plumber.
Cheers in advance for the help
Crofty
Crofty
