Fading Paint
27 Jun 2007
Glasgow
I am having trouble painting a bedroom ceiling. We stripped the walls bare leaving the original lining paper (i think that's what it is) on the ceiling - it was covered in nicotene stains but we washed it down and painted the room white. However, the paint on the ceiling seems to fade as soon as it dries no matter how many coats. My dad has to advised using woodchip (which I hate) or anaglypta wallpaper but I would like it to be smooth like the walls. I thought we could put new lining paper over the original lining paper and repaint but he seems to be against this. Is there anything else we could try or should I just strip the original lining and start from scratch?
Any advice would be very much appreciated.
No amount of coats will stop the nicotene bleeding thru.
The ceiling has either been lined without the ceiling being sealed, and the nicotene has bleed thru the paper, or the nicotene has settled on the lining paper.
The chances are that even if you stripped the lining paper, you would have to seal the ceiling before you applied new ling paper.
Here is a cheapish way of sorting it out.
Dont put any more emulsion on the ceiling now, go and buy a tin of oilbase undercoat, (must be oilbased) thin with white spirit as undercoat will be too thick otherwise, and you will be labouring, trust me, (I have just undercoated every fercking ceiling on the job I am on cause of the nicotene, and my arms are falling off) lol
The next day, emulsion the ceiling again with your ordinary white emulsion, you might have to do 2 coats, but you will have the whitest ceiling, so wear some sunglass. lol
I ave had a few ceilings like that..a recent one was covered in unpainted artex..I give it a spray with some watters down bleach first then mixed PVA in with the first coat of vinyl silk and let it dry overnight..odnt the second coat of silk..
Bosh!...looked a treat
