Fagor feb20 caravan shower issue
11 Aug 2024
Hi my Fagor feb20 only has shower issue when turning on cold water the boiler randomly trips out otherwise runs hot as, I’ve fitted a non return valve to the hot side helped it a little happens even with shower head disconnected but dosnt happen on any other taps with hot and cold running together I was told cold pressure may be to high reducing the boiler flow any advice much appreciated, what resistance should a dhw thermistor be?
Just find it odd how only cuts boiler off with shower and not any of the other 3 sinks even if the shower head is removed the boiler still shuts down
