Right this is a pain in the proverbial............
Brief history:-
Moved into house last august, ripped out all carpets. Had to remove all GF skirtings to enable DPC to be injected too. Lots of old render falling off etc and pointing on walls pretty crumbly. Gaps formed between bricks of party wall, esp where skirtings were nailed into bits of wood between bricks.
Now over the last few weeks when I have come home from work the hall and stairs smell of cigarette smoke. The only place that this can be coming from is next door (they are both avid fans of tobacco), and is worse when one of them has been at home for a few hours.
The only solution I can think of is to go mad with the pointing trowel and fill every last gap between the bricks with mortar, then re-plaster/render the walls to put a barrier up. Has anyone else experienced something like this?
Thanks for any input
Brief history:-
