Last night when my CH timer kicked in the pipes made some very loud clunks, then nothing happened. I turned the CH off, checked the gloworm closed system boiler (not combination) and it had cut out. I pushed in the safety switch back in and also checked the (Myson SD53) pump wasn't locked (it didn't seem to be), and tried turning the pump up (it has 3 settings). Turning the CH back on the boiler fired up correctly and I could hear the water pass through the pump, however even on it's top setting - 3, the water didn't seem to be flowing as fast as usual and virtually nothing was happening at settings 1 and 2. The pipe leading out of the top of the copper coil - hot water storage tank was not particularly hot and the rads didn't heat up at all for about 40mins, perhaps prompted by me turning up the thermostat on the copper storage tank to 60deg, perhaps not. Eventually the rads heated up and remained hot for the rest of the evening. However is this a sign that something is about to go seriously wrong? If so, what?! Thank you for reading this!
