I am planning to install a new bathroom in the near future.
My hot water/ central heating system is a conventional open vented gravity fed system with a hot water cylinder in the airing cupboard upstairs next to the bathroom and a 50 gallon loft tank.
To facilitate the installation of a shower pump, I have decided to have the existing hot water cylinder and the loft tank replaced. The hot water cylinder still works but is about 30 years old and I assume a new one will perhaps improve efficiency. The loft tank again is the original and certainly does not comply with current byelaws because it is simply covered by a piece of polystyrene weighted down with a brick.
I have called in a plumber to give me a quote on replacing the cylinder, the loft tank, 2 stop cocks in the airing cupboard and make the plumbing provisions for the installation of a shower pump as and when. The replacement tanks will be like for like and the provisions for the shower pump will be a feed from the top of the hot water cylinder via a Surrey flange and a dedicated cold water feed from the loft tank.
Although I haven't yet had an official quote, the plumber has given me a ball park figure of no less than £1500 and the work should be complete in 1 day. What got me thinking is that the plumber mentioned that the hot water cylinder (117 litre capacity) would cost about £300 alone to purchase. I have since seen these cylinders for £157 in screwfix, quite a mark up on what the plumber quoted.
I appreciate plumbers are expensive but bearing in mind I could probably source all the required parts for less than say £500, isn't the remaining £1000 for a day's work rather expensive ?
Perhaps I am being naive but has anybody got any thoughts or comments ?? [/b]
