I have a Falcon combi boiler and it doesn't want to work,
The power supply is OK, Gas is on, Water pressure is up for both systems, Fan is coming in OK, On the C,H The burner lights OK then after a couple of seconds it Will switch of- But NOT trip out so therefore wont reset. On the D,H,W, system when a tap is opened therefore calling for heat nothing at all happens I think it is a fault with something common to both systems.
Would be very grateful if someone could throw some light (or heat )on this before I get a fitter in.
