A
Alarm
Check the local councils.
Is it panto season again? All this Oh yes it is repetitiveness.
Which is not true....Key holders are required for all systems, check that one out too. Also to be on a register at the local council...So if you`re not doing this your breaking local regulations...
or are you going to sit up all night proving you know the internet is wrong?
Om the contrary, they are questions which the buyer of an alarm system needs to ask and then be given the answers in order that the system is installed in a way that enables the user to use the system effectively.Your post smacks of asking silly questions simply to discredit
what you said was not true.
You haven't answered yet. Which estate has a ratio of two yale alarms for every professionally fitted one?
Yes, can you take a photo of a shot of the street, as you must be in the council estate a lot changing bell box batteries.You haven't answered yet. Which estate has a ratio of two yale alarms for every professionally fitted one?
In fact very shortly after I had installed a system a home was broken into and the alarm I had installed went off and the police arrived
Righty ho.
So the Yale went off and called the Police?
That is what seems to be said here.
Just to be clear.
Got to go out but i`ll check back later as this is very interesting.
anything to say regarding the subject of wireless grade 2 systems and the frequencies getting busy and causing probs either now of in the future?
Not really.The question was, "When it is on the side or rear elevation" ?
How does the notification work then?
the thing peeps and flashes
Come on, this smacks of asking silly questions simply to discredit.
