- Joined
- 22 Sep 2021
- Messages
- 6
- Reaction score
- 0
- Country
Hi
Looking for advice on how to deal with the large space above the stairs in our house (Victorian). The stairs were previously wallpapered so have stripped this away to find a false ceiling above the staircase; this was a sheet of plywood tacked to a frame (1.0 x 1.9m with a single 'cross-beam' half way along) papered over the top with woodchip. The rest of the walls are in pretty bad shape so had intended to fit plasterboard to the existing frame and then have the false ceiling and walls skimmed.
I have been reading around the plasterboarding and am concerned that unless I build additional battens into the frame (to screw the plasterboard onto) the boards are at risk of sagging with time and cracking the skim. I will also be working by myself so am not particularly looking forward to negotiating and securing big sheets of board above the stairs!
I wonder whether it would be okay to have the walls skimmed then, when dry, reinstate a plywood or MDF ceiling (then paint this). Would this work or are there reasons (e.g. fire) that it would be superior to plasterboard and skim the ceiling? If so, would I need to add battens as I suspect or might a combination of a sloping ceiling and using thick plasterboard sufficiently reduce the risk of sagging?
Thanks in advance.
Thanks in advance.
