- Joined
- 5 Nov 2008
- Messages
- 194
- Reaction score
- 3
- Country
I want to put a false ceiling in the kitchen to lower the ceiling by about 6-7 inches to accomodate vents, water pipes etc. The span is 2.8m and the only weight on it will be the plasterboard, plaster and the lights.
Unless advised otherwise, I propose fixing 4x2 to the walls and using joist hangars at 400 or 450mm spacing. If necessary I can use galvanised straps to tie the joists to the floor joists above, but what size joist is needed for a continuous span?
TIA
Mike
TIA
Mike
