False chimney breast for gas fire and plasma
31 Oct 2004
Hi all
I am planning to remove an old brick fireplace that surounds a gas fire and replace it with a false chimney breast as you will see in the below link
see
the question I have is what is the best way to do it?
do you recomend 2x4 stud frame with plasterboard? or mdf?
where do i start?
regards
bobby
__________________
Moderator
edited to correctly insert picture
Also (and probably most importantly) what is above the ground floor ?
i.e. if the chimney breast carries on,it needs doing properly (consult a builder) or the whole lot could come down... :(
Bobby_Dazzler said:
Hi all I am planning to remove an old brick fireplace that surounds a gas fire and replace it with a false chimney breast
Why remove the old fireplace?
