false floor
14 Jan 2006
Staffordshire
I was thinking of laying down a false floor over the top of an existing wooden floor. The existing floor is a couple of hundred years old but in a really bad state has it as been exposed to the weather and unlived in for years.There are also lots of cables to be covered.I was thinking of screwing down batons on top of existing floor,insulating in the gap and covering with chipboard sheets and laminate flooring.
Would there be any problems with condensation from the living room below, which will be heated by a wood burning stove. Also, what type of insulation should i use between the two floors.
Alternatively any other ideas.
blind willy
This is the bit I don't understand, can you give us more info?
It has been a derelict building with no windows for years.The floor boards are similar to small sleepers, but they are all uneven plus it would be easier and not such an eyesore to hide new electric cables underneath than to chase out of stone or have plastic conduit everywhere.
how much height have you got play with ie how far up can you bring the new floor?
the batons I was thinking of putting down are 50mm square,floor board on top of that and then laminate flooring or cushion floor.
It might be easier (and cheaper in the end) to place your battens of minimum 50mm high and install (secret nailing) new floorboards or loadbeading wood-engineered boards on to it. In between the battens you can place insulation (No DPM though)
