- Joined
- 24 Nov 2004
- Messages
- 431
- Reaction score
- 5
- Country
when did it become "the law" to run cables across gardens in SWA?
The reason I ask is, many years ago, a detached garage electric supply was allegedly repaired by a trusted local electrician. (after the original 1930s probably rubber or textile cable + steel conduit broke)
About 10 years ago, I discovered that this supply was in fact 4mm PVC/aluminium singles run in a shallow ditch in plastic conduit.
I have now replaced this with SWA but my contention was that it would never have been done like that by a proper electrician, so somebody else must have done it - unless it was acceptable at the time (mid 1980s) to run non-armoured cable around underground.
My replacing the cable with SWA resulted in another argument about the depth of burial requirement. Is there a depth of burial for SWA across private property specified in the regs?
