Fan and light in ensuite not working.
11 Mar 2012
Suffolk
Light and fan in en-suite bathroom not working. Checked fuse box (ok), checked light switch connection (ok) and changed lightbulb -- but still not working. Was wondering what else it could be? Thank you very much for any help.
A lot will depend how the fan is connected.
Are the fan and light linked together so that the light activates the fan or are they on separate switches?
Assuming that the light and fan are linked and operate off one switch with no fcu in the way then clearly no power is getting either to the switch from the power source (ceiling rose?) or their is a problem with the switch or there is a switch live problem at the ceiling rose.
Could be a sticky or broken light switch?
Poor terminal connection at the lights ceiling rose.
Thank you for your reply. The fan has a switch and the light has a separate switch, so I guess that this points to the power not getting to both. Thank you for your help.
If the fan has an isolator and the fan and light both operate when you switch the light on. I would first check at the loop in connection at the light for loose connections.
