hi posted earlier about a smeg have noticed that when you engage the thermostat the fan in the oven cuts out any ideas on what to look at,i have changed the thermostat to no avail
It sounds like you have a neutral fault, when you are turning on the stat, heating circuit. the stir fan is losing its neutral. So you are looking for a break on the neutral side of the wiring
