Check the overheat cutout button, fuse, plug and socket first. For the next step you will need a multimeter. If it needs a new thermostat or switch, where will you buy one to fit?
It's unlikely to be a loose wire inside the fan heater, so if it's any of the components [fan, thermostat, element, switch] then they would probably cost you £15 even if you could get hold of them.
The one shot is if it has a thermal trip somewhere that can be manually reset. The instructions should tell you if that is the case. Otherwise, take it to a recycling centre
I will follow your wise words
New one purchased already anyway
I saw a youtube video
The guy was saying the fuse might be gone (as suggested)
That part looked super simple I guess
