You guys know where to find everything.
Here's the challenge.
I am installing a number of Dimplex SmartRads. The rads have live neutral and a pilot wire that connects them all. The pilot wire provides control from a master rad to the slave rads.
Power is from a central FCU near the air sourcs heat pump.
To properly isolate each rad I need to disconnect all three cables to the rad. The ideal solution would be a 3-pole isolator like a fan switch but I'll need a flex outlet for the feed to the rad.
Is there such a thing?
If not I may need to install a dual box with a 3-pole switch and a flex outlet side by side.
Thanks in advance for your guidance.
