I'd like to replace our bathroom fan which is in the ceiling void.
The wiring to the fan comes from a double switch (one for the light and a separate one for the fan) via a 1.5mm wire. Am I ok just replacing the fan with the existing wiring layout? I will get the fan from Wickes.
Yes will be a direct swap.
Does the existing fan have a overrun/humidity stat?
ie. when you turn the wall switch off does the fan stay on for another few mins?
