- Joined
- 27 Jan 2008
- Messages
- 24,903
- Reaction score
- 2,877
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a friend with a wood burner it is standing in centre of floor of a timber frame building and we have been talking about efficiency.
There is an issue which I can do nothing about very little heat storage but the burner was designed for multi-fuel which is complete nonsense as to run efficient the wood needs to burn at a set rate and although all wood gives around the same calories per unit weight they are very different per unit volume so oak burns a lot hotter than pine.
Ideal is to keep the flue at 150°C as then not to much heat is lost through flue and also hot enough to stop tar build up.
Also a combustion air feed very close to the stove reduces drafts so would make the home warmer.
So the problem is how to control air in and also cooling air flow around the stove. Clearly the best way is a new sealed stove with a vent for combustion air to the outside and a hot water store with a variable speed motor which keeps fire at exactly the right temperature. However budget will not stretch that far.
So looking at a simple fan with some switching device which will cut in as the temperature rises which may or may not draw air from outside. The standard system is a sterling motor driving a fan but again very expensive.
He can't be the only guy wanting cheap control and I am sure it has been done many times before. Although I have a spare PLC it has no analogue inputs. I have a MH1210A temperature controller but limit is 120ºC my thoughts are a temporary set-up to prove it works.
So looking for ideas rather than re-inventing the wheel.
