I am looking for some Fast Fix boxes so that I can wire some plug sockets up.
However, The wall I am trying to put these in is thicker than the average plasterboard wall.
basically, there is a sheet of plywood (15mm thick) then the plasterboard (20mm thick) ontop of the plywood board.
This means when I am using the deepest fast fox box my local hardware place stock, the two tabs either side can not be pushed out as they keep hitting the plywood.
I have searched online, however the only results I can see are deeper Fast Fix boxes, but the 'tightening tabs' still only tighten the same amount.
Ideally I need some fast fix boxes that would operate (allow for the tightening) for around a 30 or 40 mm thickness.
Does anyone know where I can get these? a link would be perfect.
Cheers.
Cheers.
