I'm just about to refit my bathroom.
I have a standard Potterton Profile 80e boiler (23kw) feeding an indirect hw system with vented cylinder. (as wellas heating the house via a closed presuurised ch system). Both are pumped. Currently two thermostatic showers are fed from this cylinder using a twin pump.
As well as the two showers I am now adding a bath/filler diverter concealed bath that requires minimum 1bar, therefore I am replcing the twin shower pump with a whole house pump to run the two showers and the bath.
Yes I am going to run out of hot water very quickly!!
I am thinking of upgrading the cylinder to a telford Typhoon (160ltr), which apparently recovers heat very quickly (30%) faster due to fins on the heat coil.
Any suggesting or experiences of this type of setup?
Read more: //www.diynot.com/forums/viewtopic.php?t=244619&start=30#ixzz1MDTmNnW0
