Fault in hot water tub
3 Apr 2010
When I woke up this morning, I turned on the bathtub faucet, but once I switched it over to the hot side, water stopped coming out (as if I was putting it into the off position).
I just recently changed my showerhead with one of those that has a 6ft cord on it...not sure if that is related.
Your hot water may be air-locked. You need to blow down the expansion pipe leading to the f&e tank.
Probably.
What has this post got to do with roofing?
Are our languages that different?
You may have a pressure-balanced type of shower valve, and they can be stuck in the "cold" position. You will need to turn off the water main, and then take it apart for inspection, lube, or possible new cartridge.
There is quite a difference :!: ;) TAPS in USA is The Atlantic Paranormal Society :idea: Faucet over here is --" If it won`t move with a monkey wrench - Force it " :rolleyes: - with a Birmingham Spanner ;)
