I have a baxi bermuda 51/5 BBU. It is failing to start or attempt to start when I have pressed the reset button but it still does not respond. It is automatic ignition. Would I be right in thinking its the PCB or could there be another cause. There is power at the boiler as LED is on. The timer is also calling for heat. Any thoughts will be grateful
