Hi can anyone help? My Beko washing machine froze near the end of its cycle. It Drains ok but intermittently and when I select any program the filter pump whirrs for about 5 seconds and then the whole program freezes and nothing happens. I turn off the washing machine and back on and try any other program and same result.
If I put it into test mode it just fills up non stop with water and I have to drain it bit by bit by selecting drain program and allowing it to drain for 5 seconds then reseting the program and draining for a further 5 seconds until it’s empty. I’ve checked the pump for potential blockages but it appears fine. The only thing different is that it’s had new brushes. Any ideas?
Read more: https://www.diynot.com/diy/threads/beko-wma765s-fault.383406/#ixzz6DZQwwAZG
