Faulty alarm
24 Jan 2010
Leeds
My alarm keeps going off after I have set it, it pleeps as normal I then lock the back door, wait a while and then the alarm goes off after a few moments, sometimes a few minutes after, can anybody help, please
What panel do you have & is it telling you anything when it goes into alarm. Is it showing a zone, tamper or fault.
So you have a tamper fault, simple. However finding the fault may not be that simple. Have you had any work done in the house recently that may have damaged the alarm. The next thing is how old is the outside bell box, could that be faulty or rusty inside.
If you are competent working inside your alarm panel then you need to check all the tamper pairs that come from all of your pirs, contacts etc. Be careful as there is 240v inside of the alarm panel. This may not be a DIY job if your not sure.
Hope this helps
Paul.
I have not used this site before so I hope I am doing it right, It is an Optima and it is showing tamper
Hope this helps
Paul.
Thanks Paul, the system is 18 years old ,time for a new system do you think,regards Steve
It all depends mate. A good alarm engineer will have it fixed in no time, but a new system is not that expensive & will give you peace of mind.
Paul.
Paul.
Thanks Paul, hope Newcastle go up this year, my son goes to the Univercity there
