faulty electric hob
26 Dec 2008
Antrim
The 2 right-hand hotplates on my ceramic hob have stopped working. Otherwise, this dual oven, fan assisted Creda cooker model C361E is workng fine(including clock and timer and other 2 hotplates in hob.
What can be wrong, and will it be expensive to fix?
Both failed at the same time or one failed & then the other later? Do you have a multimeter?
I apologise for not responding sooner. I was away over Xmas.
My wife tells me both plates on the RH side failed at the same time.
Unfortunately I do not have a multimeter although I'm sure I could borrow one.
Thank you for your interest.
If they both failed at the same time then I would suspect that you are losing the neutral part of the supply to both plates. With the power disconnected open up the hob & check underneath for obvious burnt wires/connectors, failing that you will need to resistance check the plates & associated wiring.
Thank you for this advice. I may not be able (brave enough!) to do what you suggest, but I should be able to get a family member to do so.
Again, many thanks.
