Three replies. 1, to Agile. I did as you suggested, vented the valve on the EV when the boiler was under pressure. Air escaped for about 10 seconds, then there was a very slight gurgle, and my finger was slightly wet. So, a minute amount of water, no more than a few drops came out. Since this is the case, if I charged up the EV properly, as in the FAQ section, would I be able to stagger on for a while? 2 for Gasguru, the spare part for identical replacement would cost about £60, and if I need to use a corgi installer, it would cost about £50-100 at least to do the work. If I buy an external EV for around £20 and do the job myself, then I'll be a lot happier. I'm really broke! Also, if this boiler continues to fail (a leak and something needing replacement whilst still under warranty, a new motherboard last year, and now this...and it's still only 4 years old), then I don't want to throw much more money at it. 3, for Corgigrouch, as you'll see above, the boiler is 4 years old, on it's last legs already, a true turkey. Worcester have been helpful in the past, it may well be worth pricking their conscience, I'll give it a go! Thanks one and all.
