I am a caretaker for a small primary school. An Andrews unvented hot water heater supplies the hot water in the kitchen. I've noticed a drip from the discharge pipe and prior to calling in our plumber would like some advice. I have opened the temperature/pressure valve; this lets water shoot out of the discharge pipe. Upon releasing the valve the flow stops to a constant drip (faster then the drip already coming from the discharge pipe). This takes a while to reduce to the flow of the original drip.
I also checked the expansion vessel, which sits on top of the pipework supplying mains water to the unit (using a tyre pressure gauge). When I did this water spurted out. Am I right in thinking that the expansion vessel is probably had it. If so can any plumber carry out he work or does it have to be one with CORGI registration or an unvented hot water certificate? Usually the council dealt with this direct, however this has now changed.
Any advice on the matter would be greatly appreciated.
