Hi, I've got a Worcester 20/25 oil-fired storage combi boiler. It has gone faulty, in that although the central heating (sealed system) works fine, the domestic hot water runs cold.
I have checked the installation manual that came with the boiler. If I switch off the central heating at the controller and switch on the hot water, then open a hot water tap, the boiler's pump starts up, the burner fan starts and after a few seconds the burner starts too. Great, but the heat isn't coming out of the tap! It runs warm for about one second, then it runs absolutely cold.
I've had a look at the motorised head on the diverter valve. I think it's gone wrong because the lever won't spring to one side, and the lever itself feels quite loose. Might the spring have failed? The funny thing is that the installation manual quotes that 'The valve is powered open in response to demand from the central heating'... I have tried moving this loose lever to either side, but the hot water still won't flow to the taps.
If I need to replace the motor, do the spring/s come with it, or will I need to buy a new diverter valve as well?
Kind regards,
Kind regards,
