Hello.
I'm having a problem with the service valve shown above. It's under the sink on 15mm cold water pipe just before an outside tap. The problem is that no water is getting through the valve. I have unscrewed the black handle to make sure it is actually turning the ball valve and it is. I have loosened the nuts at both ends, there is water at the bottom but nothing at the top. I'll probably just replace it but I can't find it on Screwfix.
So if anyone could tell me what this valve is called and where I can find one I would be very grateful. Also, why does it have a handle and a slotted thingy? Are there 2 valves inside? What's the point of that?
Cheers
