Faulty wall socket...
21 Feb 2005
Sorry, I'm sure this has been asked lots of times.....
I've just moved into a new property, and had my tv and dvd plugged into the double socket....when I went to switch the tv on, it suddenly switched off. Now neither socket works (I've checked with other electrical appliances)...luckily my tv and dvd work fine in another socket.
How do I go about changing this socket??? I have no idea. Any help please!!!
Initial step would be to turn off the power to the circuit the sockets are on, unscrew the socket and see if any wires are loose.
Do be careful, because as the socket doesn't work anyway, you can't be absolutely sure that it is on the same circuit as all the others.
What worries me though is that if you have no idea how to change a socket maybe you shouldn't try, trial-and-error is not a sound learning strategy for electrics....
Watch out that if you do decide to change the socket, the holes for the wires on the back of a new one may be in a different place to the old one. Do not mix up L and N. Earth should be obvious because it will most likely be an uninsulated connector.
A loose connection behind the socket is a likely cause of your problem but take note of Ban-all-sheds' advice. You can't check that the socket is really dead. Switch off the whole lot.
