My daughter has just moved into a property. There is a known CH problem that I am trying to resolve.
Hot water works but the radiators also heat up
Hot water does not work at all
Checks show that the heating zone valve (Honeywell V4043) has been set to manual - permanently on. Setting this back to auto does not solve the problem.
I have changed the controller. No difference
I have checked that the room start is switching (it is) and that there is a 240v supply on the cable when the heating is switched on. I have further found that this 240V supply appears on the blue wire of the heating zone vale. The V4043 does nothing when the heating is switched on, the pump does not operate and the boiler (Glow Worm Fuel Saver F) does not turn on.
Can someone advise the sequence of events when a zone valve should operate? Are there additional contacts on the V4043 that should sent current to the boiler and pump? In short, is it likely that a faulty V4043 would cause the problem?
Grateful for any views and suggestions
Brian
Brian
