Fax on Redcare line
16 Nov 2006
We have a Redcare line in monitoring our alarm. the phone socket on the redcare box works if you connect a phone to it and you can make calls. But a fax machine wont work even if I use a Microfilter. It just keeps ringing and not connecting , any ideas?
ther is a device that you have to put in line with the RDCARE and your fax,
speak to your alarm provider (sorry this is not a job a DIYer should be doing)
we also never reccomend using a fax or other data handling device on a REDCARE line, it can cause a few problems at the panel end as well at the ARC
sorry
Thanks, that is useful, think it will just use Skype fax then
Some fax machines are compatable with redcare,try ringing redcare support and ask there advice,i had this problem on a fault i was working on a few years back,the eu ended up having another line installed for the fax.
