FCU outside bathroom
27 Jan 2010
Sussex
Hi, i'm fitting an electric towel radiator in the downstairs loo. My plan is to use a flex out on the inside zone 2 on the otherside of the wall (in the hall) put a fused spur timer switch to control when it comes on. My question is does it matter how high I mount the fused spur timer switch? Ideally i'd like to mount it just above the skirting board so that its not in the way but I can still see it to adjust the timer.
Hi Mathew,
I probably worded it wrong the electric rad is in zone 2 just as a bit of back round. I was wondering if it matters how high I mount the timer FCU in the hallway outside?
Steve
Is there a bath or shower in there?
Current standards are to mount electrical accessories between 450mm and 1200mm above the finished floor (that is approx 18" min to 4' max)
these are sizes that you can conveniently reach even if you are fat, pregnant, have a bad back, a stiff knee, or are in a wheelchair
In an old house, you can fit accessories at inconvenient heights if you want to, but they will still be inconvenient, and as people become acclimatised to the standard heights, they will think yours look very peculiar.
Wouldn't a thermostat in the same room as the radiator be a better way to control it?
Or get a rad with a built-in thermostat?
