Hello, please help with my query re. blown FCU.
FCU connects underfloor heating in bathroom along with it's timer/stat (Devireg 540). System has worked well since professionally fitted 4 years ago. Supplier seemed to think fault can't be with Devireg system as "nothing to go wrong". Upon checking the FCU I noticed the 13a fuse had blown as well as the yellow loop wire connecting either side of the fuse on the inside of the faceplate. The neighbouring black loop was fine. Is it worth just replacing the faceplate to have the same happen again, or has this occurred through 4 years of age and is one of those things.
Please help if you can. Thanks.
