- Joined
- 27 Feb 2018
- Messages
- 12
- Reaction score
- 1
- Country
First, I realise this would be a job for a registered gas fitter and a building warrant if I wanted to go ahead. Just looking for opinions on whether it's worthwhile at this point.
We have a Baxi back boiler, still with a few years of life left, with flue running up the chimney. It's one of the ones with a 1970s style gas fire on the front. I assume at this point there's a flue liner up the chimney as there appears to be a flue terminal on top of the stack outside.
The chimney render is cracking and bossed in places and the flashing has started to leak.
When the boiler eventually gets to end of life I want to replace it with a room-sealed condensing which will go elsewhere. Once the boiler's gone, we might want to remove the wall it / the chimney sits in to open up the kitchen and dining room. But we weren't planning to do any of that for perhaps another 3-4 years.
But I obviously don't really want to put much effort into stripping and re-rendering a chimney that I ultimately want to remove. We're also this spring/summer going to build a small utility room extension that will make it harder to get scaffolding to it in future.
I'm wondering whether instead is makes sense to demolish the chimney down to below the roof line, connect the flue in the attic to a standard flue terminal, then slate over the hole in the roof.
The new flue terminal would either need to have a metre or so of external vertical pipe to clear the nearby velux, or to be re-routed to come out of the roof / eaves somewhere else. It may become redundant when we replace the boiler because it's away from where we'd logically install a new one.
Anything I do is probably going to involve a bit of wasted work, so I'm just trying to figure out the best way to stop the water coming in while minimising that. And I'm not sure how big a job re-it is to re-route the current flue.
What do you think?
Cheers,
Andrew
What do you think?
Cheers,
Andrew
