hi guys,
i would like to feed some av cables hidden away inside a chimney breast in my living room. My chimney breast has been built only upto the height of the living room and DOES NOT extend into any rooms above. The ACTUAL chimney which is hidden within the chimney breast is much smaller (approx 2ft by 2ft) and the rest of the chimney breast is hollow. Also the ACTUAL chimney DOES go into the above bedrooms.
Now I want to drill a hole to the left cheek and the front of the chimney breast to allow me to feed wires through, thus totally avoiding the actual chimney.
So my questions are:-
1. If i do a smoke test and all is okay, then is this safe?
2. Will any heat damage the cables even though they are not running through the actual chimney, but near it?
