Hi, I have a garden Shed pitched roof that needs refelting, should I use shed felt or normal felt, the 38kg is on offer at the moment £28 a roll, not sure of the for's and against's.
All depends how much you want to pay, you can get 4mm torch on capsheet felt which already has the bitumen on it( better priming roof deck first)then you heat it and the bitty melts and you stick it to the roof deck, if it's just a shed and the roof is pitched ordinary green mineral felt is usually nailed on or stuck down with cold fix tar.
