Have just tried to use flexi connectors with taps on a new basin but they are leaking at the tap end. They come with a red plasticy washer which looks a bit ineffective, and I have screwed it as tight as I can. As I sit in the office here, can you advise whether I just need a bigger washer, to use some plumber mait, or am I missing the point somehow?
The flexi is screwed onto the bottom of the tap pillar, the other end having the service valve wotsit.
You can tell I'm not a plumber, can't you?
