I'm going to be putting up a 6'x3' decorative screen vertically (see www.screenwithenvy.co.uk), using 100mm wooden posts (their posts are far too expensive). I don't fancy using post spikes as they look difficult to get perfectly positioned and vertical - vital for this job, plus it would also mean buying a sledgehammer!
Instead, I was planning to pour a small concrete footing for each post, and use those bolt down post plates. How wide and deep would each footing need to be?
Another option might be to screw the plates to a couple of paving slabs (concealed under the gravel next to the patio). Would this be sufficient, and if so what size slabs would I need? My concern here is the length of the screws, given that the slabs will be barely 2 inches thick.
