Fence Post Problem
13 Aug 2012
Yorkshire
Hello,
I need to replace my fencing.
I currently have wooden posts and plan to replace with concrete, but one of the posts is proving to be a big issue. From our level to the neighbours ground level side is a big drop, 3 feet.
Realistically the post needs to be 8 feet out out of the ground, so we can have a little bit of privacy, regarding the next panel up the slope. There our gardens are level with each other.
I can't source long enough posts, as they say anything over 9 feet breaks easily, so they don't make them.
I hope you understand my situation and would like to hear any thoughts and ideas, or has anybody come across something similar?
Many Thanks
These are available in lengths up to 3.2m (around here) but they are 125mm square against the usual 100mm.
I guess you could cast your own if all else fails....depending on how many you need!
John :)
