Fence post support fixings?
7 Jun 2021
What fixings/size should I use for a steel post support into a concrete floor to secure a fence post?
Link doesn't work.
Is the floor already constructed? If not you can cast in a support or spur.
Fences are subject to strong lateral loads from wind and will try to loosen and wrench out fixings.
I used stainless coach screws into giant plugs for my shed posts, but for a fence, 8mm studding fixed with resin will be stronger.
Once fitted, you will not want to take it out for replacement, hence I say stainless studs, washers and nuts
And paint the steel shoe with oil-based anti corrosion paint before fitting.
Link doesn't work.
Not sure why it's blocking the link but it's just the 70x70 steel post support from B&Q.
Yes the floor is already constructed.
