Moved into house 10 months ago - I have a Baxi wall boiler 10 years old and 10 rads all in 10 mm pipe- open system with header tank in attic, storage tank and pump in first floor airing cupboard - all normal all ok and system had record of fernox already added a year ago. I decided to drain system to add a rad and added normal fernox additive to protect the system at the same time got all the gundge out of the header tank. All ok but the boiler was now noisy whilst it is working - ie flame is on. Decide to add Fernox boiler noise reducer - peace, for 2 days BUT now when the boiler has its flame on, the piping around the pump and the storage tank start to vibrate fairly loudly after the boiler flame has been on for about 10 mins. If the room stat cuts in and the boiler flame stops all is quite - as the flame starts agian so does the noise ? It sounds like the pump could be cavitating ? - if I turn the pump flow down the noise turns to a very loud throbbing - does Fernox noise reducer lower the boiling point of water ? If I dilute the water in the system will it help ?
Any advice welcome - thank you
HELP PLEASE !
