Fernox then?
11 May 2004
Hampshire
Following the advice (gratefully received - thanks Oilman) in response to my last post - can I assume that all cleaning/flushing products are similarly effective, or do you get what you pay for.
My local store has Fernox, Betz Dearborn, and Flushex (sometimes). Are they comparable? Are they incompatible?
Do the 'noise silencer' products work any better than, say, an inhibitor.
You'll need to do some research to find out about differences and compatability. They probably are compatible, but Fernox has more water to make the solution than Kamco so you need 4 litres of Fernox and 1 litre of Kamco.
Noise silencer is very different from inhibitor, for a different job. If you use scilencer you will benefit by running the system for a few weeks, draining and then adding inhibitor.
