I live in a rented house & been having problems with our boiler for ages which most the time you run a hot tap trips the boiler and means you need to reset it.
However if you ever do this when the boiler hasn't tripped instead of resetting it then it changes to OTC (outside temperature control) mode and ignores the thermostat making the house very chilly indeed!
Pressing the reset/otc button to try and switch it off again though doesn't work so once it's on, it's on! Also removing from power also doesn't work as when you start it up again it's still in OTC mode.
Is there anyway to get it back to normal again? Its happened 2 times before and after a week or so manage to fix it but can't remember what I did!
