Hi folks
Please help a confused Pensioner,
Having just had my ferroli 701 CH boiler serviced, I mentioned to the service engineer, that the Central heating was not heating the house
to the required temprature, his reply was that he could see no reason
why this was so except that as the outside temprature was very low
he would expect the inside tempature to be lower.IE with the room
stat set for 20deg if the outside temp is say 10deg then the room will
be 20deg but when the outside temprature falls below 0deg the the
room temprature will not be 20deg but somewhat lower. a statement I find difficult to accept.
I pointed out that the circulating water gauge on the boiler front now only reachs 50degs then gas flame goes out when itnormaly reached 65degs, again he said that was due to the low outside tempratures we are experiancing, incidentaly the engineer was a ferroli credited engineer.
The advice I require is 1 Are these statments correct and there is no fault
2 Is the Reason Because the Boiler Is Faulty
if the reason is 2 I think I need to contact a new engineer
Thanks in advance for your advice
