I have a 77FF Popular combi. The pilot light went out and can't be relit. Following the instructions, the fan runs and after 20s, the electrodes will fire when the ignition button is engaged, the pilot will then ignite. However, after sufficient time has elapsed (at least 15s) and the ignition button disengaged the pilot goes out. That is, the pilot ignites but does not hold.
The Thermocouple gives a rising voltage as heat is applied - around 14mv.
The cut-out thermostat reads zero ohms between its contacts.
The fault finding chart says that if the thermocouple and cut-out check OK then the problem is the gas valve.
Have I missed anything else that could be causing this problem?
Thanks.
Thanks.
