ferroli combi 77 ff. gc 4726704. 1990
1 May 2005
West Midlands
pilot will light if lit with a match, thermo coupling ok. problem is it will not light automatically wen ignition button is pressed, everything else working fine just the little problem of the ignition, any ideas plzzzzzz
:cool:
Whaddaya want, a part number?? Look, if you interfere with your boiler and it kills you, you'll go to prison. :confused:
im corgi registered chris,, just lacking experience as not long qualified,
came on here for help as i thought more experienced guys would help , but obviously i was wrong
:cool:
frenchie your days are going to be long and ardous if you start replacing ignition devices that only ever get used on a service. ;)
If its any help all I ever seem to replace on those is the pcb and the occasional air pressure switch rarely the ign transformer
Board is a VMF6.1 part number 3980254/0
ign transformer is part number 3980115/0
May be a quick fault finder in elec control box
Heres an extract to help u on ur way
The 'by the way' bits
Fan has to run full speed for >20 seconds
With hot water tap open Led 5 lit indicates faulty pcb
The 'juicy' bits
Microswitch on gas valve closes [80 & 81 on X1]
Relay 3 [nearest the transformer] is the one that operates the ignition and its these that often go black when faulty
When its energised contact moves to the right and then ign box is powered up [55 & 56]
Unusual for insurance to pay for stuff like this ...they usually state they are not a maintenance contract.
thanx slugbabydotcom, very usefull.... cheers m8.
8
just foned insurance & ur all rite, not covered as not a breakdown
:cool: )
