Hi
Having some problems with my Ferroli domicondens he26c
The hot water works fine and so does the heating when you put the system on override. However now it's getting colder I have put the system on to the timer mode where the system should come on at set times. However the boiler keeps tripping out and fault A 02 flashes up with and boiler will not fire up for hot water or heating. Have to reset the boiler and it works again but problem persists on every set program.
Is this a timer problem or pcb problem?
Any suggestions would be greatly appreciated.
